K11 Rollcage Q
CMF_RBLUV
gday fellas
just wondering do they make different rollcages for K11's with sunroofs and different ones for K11's without a sunroof?
probably a pretty obvious answer i wouldnt think thered be a problem putting a non sunroof cage in a super s or vice versa
if anyone knows thatd be great
cheers
Kyle
CMF_deNs
<FONT COLOR="red">Edit: Preface - What i've said here is wrong. Refer to Mick's post, below.</FONT>
I would say the vast majority don't block the sunroof, unless they have extra cross-bracing above the driver, which most I've seen don't have. Mine wouldn't, but it's not in my Super-S after all.
I've not seen ones that specifically specify if they're for sunroof or not, but really, why are you putting a cage into a heavy Super-S after all? ;)
---dens
CMF_RBLUV
Yeah well I got a super s so any cage I get I'll only be able to use the rear half, unless I remove the sunroof winder rendering it useless, anyone got a cage in their super s? Ndxxx did you have your one installed?
