Does anyone know of any company that can provide me with a K11 rear strut brace?
Dave
I found it guys on the OMP website.
Part has been ordered.
Dave
MA/1876 is for the K12, not K11.
yeah omp made one for the 1.4 k11 but it will the same. Theyre easy enough to make, they make quite a bit of difference as well
heres mine
http://img.photobucket.com/albums/v311/6453/Picture012.jpg
put it on my rear seatbelt mechanism mounts. you can even put another two where the top of the seatbelts bolts to the car and across the top of the rear dampers. then cross brace all 3. boom a mini half cage.
Hmmmmm, seems a bit of a mix up here...LOL!
Nevermind, I'll make it fit!
do you have any pic of what mounts you had to make up to attach it to the seatbelt mount, i was going to get round to attaching one lower down to the sides of the rear strut towers, is there any benifit of putting the bar higher on the side of the car and not to the struts. ive thought myself that the rear struts arnt as bad as say the front where you have a big hole to reinforce and the rear struts look strong to the body and as said above there more or less vertical as opposed to the fronts.
id be interested in making one of these up at a later date, how much of a noticable diffrence was this if any?
already got a front one need to get some decent arbs next
