K11 rear disc help
kristian
One Way Mule
Im looking into uprating my brakes on my K11. It has rear discs and abs..
Are my front Calipers the same as any other 1.3 micra?
i.e will the usual 1.6 brake conversion work?
Also the rear discs look rather similar to K10 FRONT discs and Calipers...
Anyone know if its possible to uprate the rear discs on a k11?
Seen on motorsportworlds website that they have Black Diamond disks for the rear of a k11. So imagine it would be possibly to upgrade the disks and pads atleast.
Would also think that you could upgrade to the 1.6 brakes ok, althought the ABS
sensor would have to be left disconnected.
ABS will be fine - i remember speaking to george about this and i'm sure he said there won't be a problem
that sound about right. the abs sensors are in the hubs not in the calipers. all 1.6 calipers should be the same.
A chap on MH had Almera rear discs but found they locked quicker than the fronts - which isn't the best idea....
Have a word with Pete and see if he can dig out the guys details...
