Hi Micra Fans,
Am planning to upgrade my ride but am confused on how is the best way to do so and need your advice please.
I cant turbo my car due to local laws so got to go the NA way. Also am not willing to hack my car to fit in the new stuff so am looking to go as much plug and play as possible.
So here goes my plan:
Current Engine CG10DE 1995 version
Possible Upgrade candidates:
CG13DE 1.3L 58kw, CGA3DE 1.4L 63kw, CGA3DE 1.4L 74kw
Which of these should i change to that can be as much plug and play as possible with the rest of the stuff in a stock 1995 K11 the bigger engine the better but too much modification and rewireing will just make it harder to pass my vehicle inspection and stump the poor dumb me.
Am planning to use a jun racing flywheel,Ga15 throttle body, Ga15 fuel injectors
Also what sort of gear box would i have to use after the engine upgrade for better perfomance again it will have to be plug and play.
I had spent quite a few nights searching the site and am boggled by all the different options and advice on the upgrades. Also am just an apprantice mechanic so there is alot more for me to learn before i can really DIY the upgarde process.
thanks guys for your help
