K11 multi use build?
First time posting about my own cars here, im starting a build to compete in different disciplines, hillclimb, rallysprints etc, goin to start off pretty standard and get out doin a few.bits and upgrade as i go along, it will be cg13 with lightened flywheel, 1l front pulley, 1l box, etc etc, ill attach a few pics of progress so far
The start of it
Engine out
Removing the sound deadening
Remove a lot of unwanted brackets
Remove all sealer from wheel arches
Some repairs to sill panel
Remove and blank off rotten pockets
OP
OP
Soup1
A bit of a thread revival here, things got put on the long finger but back at the car now? i can stay at it until its done
OP
OP
Soup1
Some more work done on fitting the cage, adding extra brackets to attach to the b pillar and over the windscreen
OP
OP
Soup1
Bar being added to mount the steering column lower and slightly more towards the centre of the car
OP
OP
Soup1
Removable dash bar finished and all.bare metal from removing little brackets etch primed
OP
OP
Soup1
Starting to mock up position for seat rails and steering wheel
OP
OP
Soup1
Seat rails in, steering column brackets done and pedals slightly modified
