Hello i seem to be having a little problem with my k11 micra it seems to run very badly it bogs has a rough idle is slow *well slower then it should be
after a while when the car gets warm it tends to misfire a lot and stalls after the car will start altough not very happily and seems to be running on less cylinders then four, FYI 1996 GX CG10DE - 1l, dizzy engine no ac completely stock! around 106K killometers on the clock any help or tips is apreciated ou yes forgot to mention its a german/EU spec
