Glen Club Member Jul 31, 2012 #1 can anyone make me one of these out of steel on here if so how much? Thanks Glen
solarice Ex. Club Member Aug 1, 2012 #6 Drawing it up shouldnt be that hard...not sure if i've got an inlet gasket knocking about.
OP OP Glen Club Member Aug 1, 2012 #7 im needing it without the bump for the injectors so it just a oval
solarice Ex. Club Member Aug 1, 2012 #8 so you're looking for the gasket replicated in metal (you only want the bit that bolts to the head?), where you could then weld on the inlet pipes...basically like you'd do if making an exhaust?
OP OP Glen Club Member Aug 1, 2012 #9 so it looks like this but for a micra http://www.ebay.co.uk/itm/Peugeot-106-GTI-Saxo-VTS-INLET-Manifold-Flange-Plate-Aluminium-Bike-Carbs-/330766945918?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d033f0e7e
Skinner_87 Aug 3, 2012 #12 Glen said: can anyone make me one of these out of steel on here if so how much? Thanks Glen Click to expand... You could try BoggBrothers Glen they have a stock of flanges normally, also the bump for injectors is often kept to help the flow as far as i know eh
