K11 fault dodes 141 143
Any advice?
fuel at injectors and spark. no fuel reaching head.
EML constant flashing
1100 twin cam. just wont run
advice please.
Cheers Doug
Cheers Guys
If i cant solve was thinking of changeing ECU.
Can I buy a secondhand ECU and keys and just bolt on?
Or do I need any other components.
Thanks Doug.
Thanx for the link.
But been offered a ECU with keys will my transponder and other bits work with it??
Cheers Doug.
If cant find problem,will proberbly buy the ECU,IGNITION,transponder been offered one with key for £40.
Good move???
if you swap ecu you need obviously ecu, transponder ring from around ignition and key to match ecu or just the code chip from the key to match the ecu
mate check your ECU for water damage. My heater matrix had a small hole and the water had got onto the ECU causing EML to come on and car would randomly cut out... worth a try :p
