K11 Facelift Headlamp Glass Removal
pjg1979
THIS IS MY BOOMSTICK!
Hi Guys and Gals,
I've seen that a few of you have removed the glass from the Headlamp and painted the surround, I've got my headlamps off recently and I can't get the glass off, how do you do it?
from Phil
I think if you check modded's blog he says how to do it, but i think you have to heat them up in an oven or with a hairdryer, as theres a sticky glue strip that holds the glass on iirc.
low. I normally use about 100c for 5-10 mins.. checking regurly. be careful - its easy to wreck your headlights doing this but having said that ive done it 6 times or so with no problems :)
Managed to use my heat gun at work, done a good job as well, let the modding begin. It's quite good that the sealant around the headlamp stays workable for uto 5 minutes after heating, might re-use it once I've finished.
