Noticed some news that the UK may be moving to E10 fuels going forwards, do I need to be planning new lines/tank for my CG10DE engine Micra?
Thank you so much for that, settled my worried mind on the matter. Will have to start saving for a K12 perhaps if they review it in 2020 and deem the only solution to be the expensive Vpower fuels..
They better not! My micra only has 40k on the clock!
MSN said all micras are compatible, if you believe msn.Yup, UK seems to be moving forwards with E10 in most stations. 10% Ethanol and 90% Petrol I presume.
It's cheaper in Australia, no real benefit to the motorist, it is a renewable fuel source though but that has proven to have undesirable effects on food prices if agricultural land is diverted to ethanol production, if a waste product then it's an extra earner for farmers. I'm on a micra Australia forum I could ask what if any problems micra owners have had running e10.
E85 has a higher octane rating than premium unleaded so it's a tuning fuel, available at pumps but it can be hard to find, flex fuel sensors can mean you can run both but if your static compression ratio is too high the tune is going to struggle to avoid knock, a turbo would have more levers to pull.
We went through the same scaremongering when it was introduced here now most people couldn't care less and many tuners are using E85.Also, you can't have to much faith in our european /u.k. governments choice of fuel after introducing diesel cheaper, only for it to be the same price now and their plans to faze it out now they say it is bad environmentally and the diesel gate sagas.
