Antony
just need a cylinder head with valves. anything in decent condition that can be cleaned and polished and used.
if there is anyone with a skimmed head that they no longer need or if anyone wants two cylinder heads in exchange i have two here you can have..
one has had an inlet cam seize in it, its painted red, comes with all 16 valves (perfect condition) thermostat housing still bolted to it, all valve buckets still in it and cam caps.....
the other is one i have started to modify (like frank did with his low compression head, taking the combustion chamber out to the shape of the gasket) but never got round to finishing it...(the work i have done would dissapear with a 2mm skim) this would come with all the valves still in it, the engine it came off was from craig and is believed to be a jap spec March CG13, but i cannot confirm this..
i ca even do you a cam cover in a colour of your choice..
thanks guys...
thanks guys...
