k11 ABS front hubs
NeX
You're after my robot bee
hi all need some UK spec front hubs for a k11 with the ABS sensors in them
THANKS LOADS!!!
rare to find i believe. if its just the bearings thats duff then i'd just get new bearings pushed in.
the problem is that my march has a broken ABS sensor, and rather than replace the sensor i thought i could change the whole hubs and that way i could fit different calipers on (otherwise i am stuck with the brakes i got as they are part of the hub) but i don't want to loose the ABS
