Hi there again , since November been trying to get the K11 going ,1994 model, still non starter, changed ECU ,spark ok, fires when use easy start. ,
Eng cont Relay ok
, INJ fuse ok , this is a pre NATS ECU which has been changed , fuel pump good as can hear it work and relay working prior to turn over, pump fuse good .
Maybe need the Nissan Consult ,but it will say fuel fault !
Does the ECU need programming to make it work ? Is there an immobilizer inside it ? Like this one
This is a common problem but divided into Pre Nats & various NATS solutions , so any help gratefully received !
Cheers
Eng cont Relay ok
Cheers
