hissyfizzy
Ki0
I've done all that. Would a failing distributor cause this kind of issue? Seems to be an awful lot of K10's all of a sudden failing around the same year as mine 17-20 year olds and most of your replies seem to suggest distributor failure.
What exactly will happen if the distributor starts to fail and what symptons would I expect?
hissyfizzy
you,ve changed just about everything now, are you sure theres no blockage fuelwise, rust in the tank/blocked pipe/blocked fuel filter ?
i would take the inlet pipe off the pump and blow down it and get someone to listen in the tank
if it runs when you chuck fuel down the carb still, it gotta be starvation still ?
