K10 Radio Cuts Out When I...
Shaun
***StaGGeRed***
...Use Anything Else, Basically I Was On My Way to Work This Morning And Was Listening To Hollywood Undead When I Used My Indicators For The Roundabout The Stereo Breifly Cut Out And Then Turned Itself Back On It Keeps Doing It Whenever I Use The Brake Pedals Indicators Lights Or Fan/Heater grr
Any Suggestions? It Just Started This Morning :glare:
Bad connection on the fuse running them circuits,happened to me on the st.
Use some electrical contact cleaner and inspect the fuse box:grinning:
It's the music you're pumping through it, the rest of the electrical system is trying to kill it.
I suggest checking connections
okay i have found out that when i wiggle the little black connector box just off of the positive terminal the whole interior goes off/on probably a broken lead before i cut it off and replace it does anyone know if there is anything inside it i need to worry about like inline fuses etc.?
