superls
K10 Tuner
hi all,
need to find out a couple of little things before starting my latest project.
does anyone know the stock valve duration and lift.
can anyone suggest any durations and lift which better suite a turbo car, such as the figaro valve duration and lift, (if different from the non turbo ma)
ive read a couple of things mentioning that when turbo'ing reduce the compression ratio. ive hered of spacers used between the head and block, 2 headgaskets, and obviously custom pistons. but as i have a couple of spare sets of pistons and metal working machinary could i not just take some off the top of the piston?
also how is the compression ratio calculated?
what is the c/r of the figaro as a comparison?
cheers i think that is all for know, thanks in advance superls.
