Location Powys (Mid Wales)
Testing the water for interest:
I am willing to split items that have a letter listed with the numbered item......Also items in category 13 will split....Others to be kept as a complete set
Enjoy
ITEM 1:
MA12 Head (Non-EGR) Has had two previous skimms during its lifetime
Complete with:
-Releived and smoothed external ports to match stock gaskets (including EGR restriction on Exhaust port 2)
-Releaved and smoothed internal ports (including around the spark plug ports)
-Port-Matched Inlet manifold (requires PCV)
-New Timing belt
-New Valve Springs
-New Valve Stem oil-seals
-New Camshaft oil-seals
-Valves lapped-in
-All Gasket surfaces hand-stoned
-New head gasket
-New Exhaust Manifold Gaskets
-New Inlet Manifold Gaskets
-New Rocker Cover Gasket
-New Thermostat housing gaskets
-New Thermostat
-New Carburettor face gaskets
-Electronic Ignition Distributor
Thoroughly degreased, rinsed, dried all parts.
Assembled.
*Requires a pair of locking clips for the rocker shaft*
ITEM 2:
Customised 3-peice Stainless steel exhaust system (very quiet and very free flowing): Manufactured by AAS Exhaust Systems
-Complete with:
-Free-flowing 4-2-1 Exhaust Manifold (sequentially paired primaries)
-Bosch Wideband Oxygen / O2 / Lambda sensor fitted in the manifold collector (including remote signal conditioning interface)
-Flexijoint (Scrubbed / Dammaged)
-Center section fitted with a large silencer
-Rear section fitted with medium silencer and plain exhaust tip
-All mounting points match the OEM mounting points
-Formed oil dipstick to match the manifold pipework routing
*Requires a pair of pipe section flange gaskets*
ITEM 3a:
Datsun boot / tailgate ("titless")
Complete with:
-Mercedes Arktic Weiss (147) two-pack gloss
-Upper and lower spoilers (FOHA) fair condition
-Retrofitted rear windscreen wiper and washer and associated wiring (post-facelift nissan electrical connectors)
-matching (smaller) rear light clusters
-high-level brake light
-Modified "double barrel" lifter struts (no more winter scull splitting)
*Requires printed glass heater repair (aproximately 4 lines broken)*
ITEM 3b:
Side Skirts (FOHA) fair condition
ITEM 3c:
Front splitter (FOHA) broken into 4 peices,
*requires major structural repair*
ITEM 3d:
Rear skirt (FOAH) in fair condition
ITEM 4:
Modified facelift grille
complete with:
-full / main beam suplement light bar & relays, fuse etc
ITEM 5:
Modified Super-S dials:
Features Retro-style Nitrous Oxide (N2O) system warning Lamp
ITEM 6:
MA12 Engine block:
-Stripped, cleaned and boxed
-Conrods, wrist-pins and original pistons are still assembled, rings disgarded
-Original Oil pump
-Original belt tentioner / idler pulley
-New oil-filter
-Oil Sump repainted
-New coolant inlet pipe o-ring seal
*Requires 1st oversise rebore* (Approx £100)
*Requires 1st oversize piston & rings set* (approx £200)
*requires new crank shaft bearings: Journals, thrust and big-end*
ITEM 7a:
Clutch and preassure plate (worn to around 70%? in otherwise good condition
ITEM 7b:
spare low-mialage clutch friction-disk and preassure-plate
ITEM 8:
14" 5.5J steel wheels with 175/50 Tyres
ITEM 9:
13" 5J original steel wheels with 195/45 Tyres
ITEM 10:
4 speed manual transmission / gearbox
ITEM 11:
Magnacore 8mm (?) RED Ignition lead set
ITEM 12:
K&N Air filter Element cleaned, dried, oiled and fitted to a modified air filter housing
ITEM 13: (See http://forum.nitrous-advice.org/viewtopic.php?f=6&t=2799 for the 5-page project write-up with photographs)
Spare Modified Carburetor plate (to accept Wizards of NOS crossfire nitrous and fuel mixing injector):
Wizards of NOS parts:
-Nitrous controller computer (Max Extreme)
-11lb nitrous bottle (empty) complete with:
=Aluminium billet hand valve
=Safety Pressure Relief Valve
=Electric bottle heater
=Aluminum quick release mounting bracket
-Nitrous-Pulsoid (blue) fitted with 50-shot jet (+25bhp power adder)
-Fuel Pulsoid (red) fitted with jet matched with the above nitrous jet on MA series mechanical fuel pump
-Crossfire Nitrous and fuel mixing injector
-Fuel Take-off Tee
-System Arm/Disarm aircraft switch with red safety cover
Enjoy
ITEM 1:
Complete with:
-New Timing belt
-New Valve Springs
-Valves lapped-in
-New head gasket
-New Thermostat
Assembled.
ITEM 2:
-Complete with:
ITEM 3a:
Complete with:
ITEM 3b:
ITEM 3c:
ITEM 3d:
ITEM 4:
complete with:
ITEM 5:
ITEM 6:
MA12 Engine block:
-Original Oil pump
-New oil-filter
-Oil Sump repainted
ITEM 7a:
ITEM 7b:
ITEM 8:
ITEM 9:
ITEM 10:
ITEM 11:
ITEM 12:
-Fuel Take-off Tee
