edzmen
I’ve recently been experiencing a strange fault with my K10’s engine, and I wondered if anybody had any ideas how to fix it:
My Micra is a J-reg LS model, with the 998cc [MA10??] engine.
Of late its developed a seemingly random fault where sometimes I just loose all smooth drive from the engine when I depress the accelerator - mainly in 2nd & 3rd gears – the engine ‘stutters’ badly combined with very jerky acceleration and big ‘holes’ in the power delivery when I depress the gas pedal.
The first time this fault happened I managed to cure it by accelerating hard in 3rd gear, but today the fault occurred in 4th gear on the motorway, and I had to pull over and turn off the engine before it fixed the problem.
Also this time the engine was juddering in 1st gear with the accelerator depressed, and it died completely when I depressed the clutch fully.
Im sure its not muck in the fuel system because I had the fuel filter replaced only two months ago when the car had its full service.
I spoke to one former Micra owner who said they had experienced similar with their car, and had to change the throttle body to fix the problem.
Anyone got any ideas as to what might be causing this problem?
Cheers!
Cheers!
