Makrakin08
will you be doing any body work to the car after the transplant is up and running? i think you should do something different
Alot done today. Wiring finally sorted today all except the fan, I've miss-placed the plug for the primera fan so that stopped finishing that. I cut it off the primera loom a few weeks ago and put it somewhere safe so safe I can find it now. I mounted and power-steering reservoir and ran pipes to pump. Fitted exhaust need a new back box but did a patch on it just for a test drive. I still need to bleed the brakes was going to do that tonight but when I took a look at the pads they need replacing so I'll pick up a set tomorrow do brakes then. Still a few little things need tidying but once I do the brakes I'm ready for test drive. So maybe a short run Tuesday night. So close now.
What mods to the suspension have you made exactly?
I had a look through your thread but could only find reference to shocks and springs.
Personally though i think you maybe fighting a losing battle with the weight of the ga16 engine and box.
Iam worried what fitting a 1300cc 16v into my 1000cc k10 will do. I have k11 front and rear anti rollbars and cut springs and i dont get any understeer or oversteer. Iam about to upgrade to k11 hubs, brakes, lower arms with the p bushes and i will also fit mk2 golf coilovers when the arrive.
Kev
