boyracergt
basiclly bit of rant and couple of questions
1. autochoke: annoys me a lot it cuts in everytime i start it, stays on for 15-20minutes and ticks over between 2500-3000rpm also get a lot of smoke not sure if this is normal. ive knocked it out during this warm weather by twisting the heater cover to the furthest timing mark now it doesnt cut in. is this ok will it cause any issues or is there a better way to cut it out
2.idle speed control: rear window heater, main beams only and heater blower raise the idle speed but side/dipped lights dont and when turned on lower the idle speed about 50-200rpm and also my sound system combined with diped lights causes a 850rpm idle speed to dip to 350rpm is this normal is there a way to get the idle speed control device to cut in with dipped lights/ sound system.
3.is there a bigger car that had the same carb with bigger jets i know ma12s have smaller jets than ma10s is there any other jets that will fit?
4. has anyone ever considered twin standard hitachis? or are they not adjustable enough?
this has been covered a few times but sometimes its hard to find the relevant threads so thought a thread that clears things up would be good.
carbs that fit and what you need to fit them the only ones i know of are:
* weber ich 34 which needs an adapter plate between carb and inlet. adds approximately (from what ive been told) 9bhp
*Cherry/sunny carburettor should bolt straght on bigger yet very slight power gain maybe 2bhp
if im wrong please correct me and excuse my ignorance. rant over, now for discussion
