Hi guys,
I'm new to the forum so first I'll introduce myself!
I've got an old K reg Nissan Micra 1.0, which has been in the family for about 10 years. Recently the timing chain tensioner went causing a lot of valve damage and I decided to replace the engine and get it back on the road to give to my girlfriend as she needs a nice cheap car.
So far replaced the engine, clutch, lower cross member, brake pads, all service parts and oil. All looked perfect...
Engine primes, starter engages and spins... smells fuely... all good... But no spark!
Checked all the ground connections and they all seem fine. But for some reason there seems to be a problem with the ignition circuit / cam position sensor circuit. All the fuses are fine and I've tried replacing the coil pack / distributor with one which I know works fine because it's from the old running engine. I'm not the best when it comes to schematics and electronics, but I'm wondering if I might be missing a ground connection to the coil pack? Does anyone have any ideas at all because I'm totally stuck...
Could I have missed a ground connection somewhere or reconnected the loom incorrectly?
Any ideas would be hugely appreciated!
Thanks guys...
Mike
Thanks guys...
Mike
