Morning..
I need to swap from a 1.0 coil pack to a 1.0 dizzy engine...
Am I better off pulling the engine and box out the top or.. undoing top mounts, subframe etc and dropping the whole lot out the bottom?
Am I going to run into any problems swapping the two over or will it be pretty much plug and play? I'm going autograss set up with the wiring, so starter, ignition, fan etc will be on toggles so all the ecu needs to do is injection...
Will.
Will.
