Titch said:Well done guys!
So is it now a 1.4 turbo?
What sort of power you putting out now mate?
Davey C said:hks manifold IIRC and a T2 garret turbo
Davey C said:he is using all std parts, cluth, gearbox, driveshafts etc
have a feeling the clutch wont last long mind
Titch said:Davey C said:he is using all std parts, cluth, gearbox, driveshafts etc
Wouldn't of thought so.
Take it he'll be changing everything in due time? Really want to see what kinda power he'll be running at!
Layla said:his ebay story was just to cover where he really got the parts from.
All I need to say is it will waste any NA 1.3 micra here without trying.
SR_Micra_Boy said:All I need to say is it will waste any NA 1.3 micra here without trying.
Pretty much stating the obvious there arent u ed, his 1.4 wasnt exactly slow as std.
Titch said:SR_Micra_Boy said:All I need to say is it will waste any NA 1.3 micra here without trying.
See thats what i thought to. Remember that video of Neil racing James at the Pod, and neil getting humped. But thats what i'd expect from a modded 1.4 against a 1.3.
So now - yes it will destroy a 1.3 but should be nailing the likes of vts, 106 gti's, etc etc.
I know it not all about power, but if not then what was it done for!?
My 2p
Titch :kungfu:
SR_Micra_Boy said:Pretty much stating the obvious there arent u ed, his 1.4 wasnt exactly slow as std.
Ed?Craig said:What injectors is it running, does it still have 4?
Ed said:SR_Micra_Boy said:Pretty much stating the obvious there arent u ed, his 1.4 wasnt exactly slow as std.
Also as a side note all K11s have closed loop lambda you have to or it wont pass emissions. That video is very old also (2001) modded 1.3 K11s get easily into the low 17second 1/4miles (even high 16's)
Titch said:but should be nailing the likes of vts, 106 gti's, etc etc.
Titch :kungfu:
Craig said:Ed?Craig said:What injectors is it running, does it still have 4?
Titch said:Well in the video (think it's in the vids section) Neil gets beaten by him. And yes - neil has the Janspeed to.
Craig said:Are you going to put a larger MAF in then?
Will be interesting to see what it is like after this weekend
Davey C said:Craig said:Are you going to put a larger MAF in then?
i believe its being treated to a Gtir MAF sensor, and yes i cant wait for the results either i bet james is going crazy about the wait lol.
