Courior
Fat ppl r harder 2 kidnap
Ok well im poor and cant afford a full exhaust system yet... Im not after power gain really, all i want is look and a nice sound, not loud, just not stock either. Now i bought a nice exhaust tip that is actualy quite wide and clamps to the pea shooter with the usual outside bolts, now for my plan.
The Tip is a £20 ripspeed one from halfords. its about 2" wide on the bit that slides onto the original exit pipe. If i grind the little exit pipe off the silencer, then widen the hole left behind so the end of the exhaust tip fits in very snugly, then either chemical weld, or weld weld it on there, will this make it louder (its loud when rust makes a hole aint it!! ). It will look nice as all you will see is the tip.. but i dont wanna go through all this to find it still sounds stock!
Advice please!
Cheers!!
Advice please!
Cheers!!
