Installing universal cruise control
Hy guys. Need some help with a lite on universal cruise control. I have one and i want to install it on my 2005 micra.
The problem is that i am not able to calibrate and probably connect the wires correctly.
Anyone with some "wiring" experience?
I managed somehow to connect the central unit, the cruise controls but i am not able to find a wire which is actually named " speed signal" or in French "pulsation de la vitesse".
Anyone any idea?
Thanks in advance!
Sent from my W_C800 using Micra Sports Club mobile app
Not really had much to do with k12s but I would think it would be speed signal to speedometer from gearbox (presuming it has a sensor not a cable drive) if you could get a manual it should give you an idea and probably give you the wire in the wiring diagram
Sent from my SM-N950F using Micra Sports Club mobile app
Yes that s right thanks. The problem is that i am not able to identify the correct wire.
