installing central locking in a k10 ?
I fitted one from maplins in a day, it's easy peasy, just follow the instructions. The tricky bit is getting the door cards off, but that's not sooo bad if you've got a haynes for the K10
I started yesterday with it. It's plug and play. But you have to put the cables trough the door. And that is the hardest thing to do.
Good luck!
