no cos then the amp will be on when the car is, the on remote is smarter and only comes on when the stereo does.
yes, mine is linked to the remote lead to! turns on when head unit does and not before.
amps can be tricky to install but after you do it once....it should be natural and easier next time!!
(unless thats on a saxo or 106 lol......no grommets to go through and battery connectors are dodgy to wire up the amp power cable not to say the least)
good luck!!
try it on a citroen C2..... the firewall is full of sand..lol fwn fwn fwn
we found that out the hard way.... but managed to put it right again..
Yeh I've thought about that, although the car does have a "grey theme" to it so maybe a grey box?!?!?!?!
Was fairly simple, getting the power cable onto the battery was the hardest bit and I had to cut the battery and ground connectors that connect to the amp in order to fix. Took me a good 2 hours to get it perfected and have everything done properly
