Installing a Double din touchscreen? K11 2000 facelift. Android auto
Hey! So looking to install a touchscreen double din and just want some simple advice. I know some chopping will be required. But apart from that I'm abit clueless so could anyone recommend what stero? What size? And is it just case of a single to double adapter plug and play? Any advice and knowledge. Thanks!
Hey mate, DIN is a universal measurement single din is 50mm high and 180mm wide where as double din is 100mm high by 180mm wide.
The issue with the k11 centre console is that it only has a single din slot and then sweeps down. You are right you can use a rotary tool to trim and try and attach a double DIN cage.
But what is far easier is to install a flip out single din like this https://www.ebay.co.uk/itm/26523207...CCCKiowLxYNnwtq3exwESLc0chgpKGpBoCIw8QAvD_BwE
