installed air fiter what do you think?
CMF_Marshal
» CMF Member
installed an high flow air filter today
TFI high flow air filter- $20
TFI memorix hose-$30
old piping- free
3 inch to 2 inch pipe-$6
paint-free
total $56
tell me what you all think it is located under my bonnet scoops to give maximum air flow
CMF_fred
» CMF Member
hay thats not bad, so does that mean you've taken the paper filter out? Did u say you had a bonnet scoop there? next step is to box it in with a rubber seal (around the top so that it seals to the bonnet when closed) for some positive pressure.
CMF_Marshal
» CMF Member
fred WROTE:
"hay thats not bad, so does that mean you've taken the paper filter out? Did u say you had a bonnet scoop there? next step is to box it in with a rubber seal (around the top so that it seals to the bonnet when closed) for some positive pressure.
yeah i got 2 bonnet scoop one either side will post up a pic
hey thats not a bad idea mit just try that thanks for the tip!
CMF_sikK11
» CMF Member
i had the same thing on mine. But then i changed it and went with a piece of alloy. It worked better. Tuner said it was because the zig zag of the tubing you have used effects the air flow. I did not think it would make a difference but it did.
