insanely high revs from loose ht-leads?
hello,i've a k10 1.2 & every six months it over-revs on start-up/idle.usually the ht-leads have worked looser,but one is more-so.when they're pushed home: problem goes.anyone care to comment? regards
For a quick fix get Pair of long nose pliers, squeeze the contact clip together inside the cap slightly and replace HT Cap. Also, make sure the little screwcap on the Plug is done up tight ;)
