r reg sr won't start. Engine check light flashing.
thought it would be ignition switch like 10 years ago. Doesn't seem to be.
thought it would be key chip gone dead so changed ecu and all nats stuff with the spare ones ive had lying around. still no luck
changed relays fuses with spares. still no go
new battery as old one was giving up. no change
engine check light flashing. injectors are cut off supplying no fuel.
when i changed the ecu with matching key and immobiliser unit engine check light stopped flashing car started but few seconds later injectors cut of again
cleaned engine bay earthing points . still injectors cut off and engine check light flashings. gave up for the day. any ideas welcome.
thanks
thanks
