Hi,
I have been told that with CGA3+CG10 gearbox, + fast inlet cam (its 250deg/9mm), and the simple GA16 + CAI mod, that the injectors will be on 100% which is dangerous.
So what recommendations have people got for injectors?
Matt recommended the K12 1.4's, but I know people have used Primera 1.6 ones as well, and some others.
The thing I am confused about is I have read on a few threads on MSC that stock injectors are good for up to 100-110bhp. Surely a CGA3 with just a better inlet cam and airbox mod is going to be around 90-95bhp (i hope!), so whats the problem?
Can someone clear this up for me please? Thanks!
PS - I know the full potential of the cams will not be released until some proper management is done - this will be done eventually!
Also, is it true that if injector upgrade is done, then remap is a MUST, because the stock ECU will not be able to run the upgraded injectors properly?
