hehso go on Frank enlighten me, you know you want to
i had one fitted a while back karl, they,re only 50mm tho eh, i prefered the SR one personally (there,s no built in maf in either of them tho eh)I'm thinking a qg18 tb might fit, though I'm more than likely wrong
Does the sr have the same stud pattern as the coil pack?
the SR t/b has a square bolt pattern karl, 2 of the bolts line up, but you need an adapter plate for the other 2, some pic,s here http://www.micra.com.au/community/message.php?messageid=65695so if ibought this it'll bolt to the coil pack inlet mani? or will I need an adaptor plate?
