Baz
Are standard Starlet turbo (295cc) injectors compatible with the impedance on the st?
I'm planning to rebuild my st's engine after JAE because mainly has piston ring wear now and a bit smokey under acceleration (No doubt Steve will see on the way to JAE) looking to run a little more boost 1.4-1.5 bar on the fresh engine?
I'm looking into also getting a stainless tubular manifold and downpipe for more flow, some minor head work on the ports. Might look into some forged pistons although with cooling kept under control and the fueling I think the factory ones are ok
Also on the cards,
Oil cooler (Oil temp is quite high on track)
Larger Radiator
Chargecooler. . .maybe!
Turbo reconditioned small bit of play in the shaft
Headgasket, standard one is still going over 3 years later at 1.2 bar boost and a few 1.6 bar blasts when i had a boost controller problem while drag racing the car lol
But question is would it be able for this? I think the main thing is keep the temps under control?
Now I know alot of the guys dont want to boost the #### ( for want of a better word ) out of their st's but I think it can be done and still be reliable as I usually drive around on moderate boost levels
Obviously gonna be harder on clutchs but I dont mind I go through 1 a years as it is and can change a clutch with my eyes closed at this stage(Y)
Gearbox is going to be rebuilt as the bearing can be noisey at times, but the car has been on track alot . Still selects all gears perfect, sometimes the syncro in 2nd gets a battering but seems to be holding up. I have had the box apart twice in the last 3 years and no visible sign of wear on the gears and no metal in the oil.
Also on the cards,
Larger Radiator
