mine ran too rich low down with GA16 injectors, and i would have to pull the fuelpump fuse just to get it to start,
but the QG 15/18 topfeed ones didnt overfuel as bad for some reason.
the current SR20 ones are fueling very nice at the reduced pressure from the rising rate fuelreg.
i had expected worse fuel milage from the reduced atomisation, but i think petrol is so flammable that it makes no difference, unlike diesel, which would suffer badly i guess, and with durations over 30% you,re spraying petrol onto a closed inlet valve anyway eh (no atomisation if you,re sucking it back off the inlet mani wall !)
the key to getting a bigger t/b to work, is to increase the fuel ONLY at wider throttle openings eh, and i think most ecu,s only have a fueltrim that extends to 25%, so once you excede that it will start throwing wobblies
