Basically you need to fit hubcentric wheel adaptors, this means you will bolt on a aluminium block to your Nissan hubs, from this you will get your 5 stud adaptor.
Demon Tweeks do a range of wheel adaptors, the problem you might have is that the adaptors usually result in spacing out the wheels by a minimum of 20mm so you would need to fit wheels of an offset of around 55 to 62 unless you plan to fabricate some wide arches?
