Hydraulic clutch?
Is anyone aware of a kit to convert a K11 CG13 to a hydraulic clutch system? or has anyone done it?
I'm going to be using mine in a mid engined configuration so it's going to be a bit difficult to continue using a cable system. The car already has a hydraulic clutch system with the current engine.
I know there is a Wilwood slave cylinder that pulls rather than pushing like the majority do so I've no doubt I could create something but if it's been done before I see no reason to re-invent the wheel.
Iain
Any ideas on how that would fit to the engine? is the bolt pattern of the bell-housing is the same? and what about clutches and flywheels?
I've just been having a look on ebay and from the pictures on there it also looks like the gear linkage is different (cable?) which might make another aspect of the job simpler.
Iain
the bellhousing bolts look very similar iain (as is the CG/CR block, bar the alloy sump on the CR)
the g/box itself looks very renault-esque tho
