T Tech936 Aug 16, 2013 #1 So this is my little red tank looking to turn her into this. My question is were would u start a tut on this would be nice cheers in advance Attachments 1376649266232.jpg 146 KB · Views: 406 1376649316808.jpg 69.5 KB · Views: 414
Skinner_87 Aug 16, 2013 #2 Nice clean motor mate! To swop you'd be after Front & rear bumper (different front bumper brackets needed) Wings Headlights Grill Bonnet And away you go Something to watch the lower mounting bolts on the wings normally snap off!
OP OP T Tech936 Aug 16, 2013 #3 Cheers for the tips man also the peed limitor caps off at 112 anyone know the way to remove this??
skymera Brutal Honesty Aug 16, 2013 #5 Tech936 said: Cheers for the tips man also the peed limitor caps off at 112 anyone know the way to remove this?? Click to expand... Why? Speed limit is 70. It's probably the rev limiter to stop yourself blowing the engine up Tech936 said: Would Silvia headlights fit?? Click to expand... With some work. Someone else fitted Mk4 Golf lights. You'd also need the front bumper bottom lip, pretty rare and pricey.
skymera Brutal Honesty Aug 16, 2013 #7 Tech936 said: Skymera how have u been u going jae?? Click to expand... I'm fine thanks mate. Life's busy I'm not going to JAE, I pulled out a while back. Hopefully next year!
OP OP T Tech936 Aug 16, 2013 #8 ,what!! No skymera this year dam. Hopefuly ill have the tanks body work done beforhand
oldcrow Aug 31, 2013 #9 Skinner_87 said: Nice clean motor mate! To swop you'd be after Front & rear bumper (different front bumper brackets needed) Wings Headlights Grill Bonnet And away you go Click to expand... Do you know if the Bonnet Hinges are the same between facelift and pre-facelift models?
OP OP T Tech936 Aug 31, 2013 #10 no idear mate will have to have a look once I find a pre facelift bonnet
Skinner_87 Aug 31, 2013 #11 oldcrow said: Do you know if the Bonnet Hinges are the same between facelift and pre-facelift models? Click to expand... Pritty sure they are the same fella
