CMF_hunterz
» CMF MemberHello I have a '99' micra profile 1.0L.is it just the pre face lift models that have the self diagnostic feauture and how do you activate it.
cheers
cheers
hunterz WROTE:
"Hi so I will need to get a code reader for mine.is there a way to check which one I have.
cheers
frank2 WROTE:
cheers"</div>
your 99 model should have the earlier 14 pin square diag plug hunterz, eobd2 has the trapezoid shaped 16 pin plug
frank2 WROTE:
"yours should have a checklight in the dash mate, its only the very early k11,s that only had the led in the side of the ecu
frank2 WROTE:
"the ecu is the one at the back hunterz, maybe the other one is airbag or nats ?
