How do you check the windcreen washer fluid level?
Scott Cruz
As the title says...
How do you check the level of the windscreen washer fluid on a K11?
I cant seem to find a Min / Max level or anything anywhere.
Cheers.
you dont really, you just fill it untill it comes to filler neck. You may be able to check level on the washer cap thing, that goes down it, like a dipstick.
Fair enuff, thats what I was doing, just basically topping it up till I see it in the tube then checking it every now and then.
I just wanted to know if there was an official way to do it or anything.
Cheers guys, thanks for the help! (Y)
Ahh just fill it up to the top, its not like you can overfill it and its only really water and abit of soap so its cheap and easy enough to do.
Fill it til your feet get wet. Use as necessary until no water accompanies the sound of the pump. Refill until your only-just-dried tootsies get wet again. Repeat ad infinitum. HTH ;)
