T tryme Nov 24, 2009 #1 I've just noticed my exhaust is blowing so it must have a hole in it. I was just wondering how much it usually cots to get it welded up or whatever.
Arnold www.alanarnold.co.uk Moderator Site Supporter Nov 24, 2009 #2 Depends where the hole is. You can buy tape repair stuff from halfords to go around the pipe or box if it's small enough
OP OP T tryme Nov 24, 2009 #3 ok but when it goes through the mot next time will I have to get that done properly.
micras69 Deactivated Account Nov 24, 2009 #6 the most expenceive part of the system (apart from the cat) is only £18 so i would just replace the worn part
B badj Ex. Club Member Nov 24, 2009 #8 eurocarparts.com, onlineautomotive.co.uk are another (might have a hyphen in there somewhere). both have good prices for exhausts. Its better to fix it properly than a half arsed job that'll keep coming back (or get worse)
pollyp Club Member Nov 24, 2009 #9 i get mine from unipart partco. middle pipes £25, silencer £24, cat gasket £3 and silencer gasket rings £2
B badj Ex. Club Member Nov 24, 2009 #11 Partco are pickup only unless you have a trade premises, both the sites I mentioned deliver.
OP OP T tryme Nov 27, 2009 #12 the holes about the size of a 5p if that, it's in the pipe just before the back box.
B badj Ex. Club Member Nov 27, 2009 #13 just put some gungum repair tape over it then if its small, does the job good enough
