hello everybody
today some one told me to put some car oil in the throttle body (remove the oil filter box and putting oil in the air that goes to the engine) to clean the throttle and improves the engine performance
so I did that I put some 5w30 there and there was a lot of smoke out of the car for few minutes after that everything was ok but the rpm still on 1500 or little more even remove the battery wires turn off the car remove the sensors wires in the throttle body and putting the battery and try to starts the car again still the same problem
so may the problem would be cause on of the sensor or what and how can i fix that
or should I reset the ECU to the factory setting (by the way i don't know how to do that) or take it to someone to check the car via OBD
please tell me what to do know
