Hi everyone, my names Adam, and i am from Sydney Australia.
The Micra is my daily driver, it gets some attention and modifacations, but i need it to be reliable, and it has been since i have bought it but it has started loosing power and stalling violently.
At first i thought it was heat related, as i was on the freeway for an hour just driving in 4th (slightly underload, you know just sticking on a certian speed), then suddenly it started loosing power, then coming back, and as soon as i pulled over i stalled, it seemed to do this on every hill it had to climb too.
So i changed a few things (intake setup) and it hasn't done it for a while, until now, it has started doing it again.
So i had a search through all the guides and they seem to have a common problem with the soldering on the throttle body. I have just attempted this, but to be honest, i'm not confident that this would fix it.
However, when you pull the larger brown plug out, it does tend to act like it did randomly. (rough, variable idle, lack of response with throttle). So maybe it will fix it, i'm yet to take it for a drive though.
I noticed that there were not many replies in these threads being made to say that this or that worked for me, so i am asking, did you have similar problems to me, and did the throttle body trick fix it?
Since i have done this throttle body trick, the idle seems to be a little low, and throttle response seems to be a little sluggish, maybe thats why i am not confident ... i shall do some searching to adjusting the idle now.
Thanks guys,
Adam.
Edit: just raised the idle, sounds much better! and has the response it should have at the touch of the throttle.
Now to see if the thing will stall on me or not ... thats another issue.
Thanks guys,
Adam.
