CMF_LX97
» CMF MemberLast night when I drove to work I found that the fan would not blow on any settings except the fastest.
With the current temperatures in the mid thirties I was keen to see if I could fix the darn thing.
I did a search and read that this is a common thing to happen with the Micra.
Two years ago I bought this car and only one fan speed did not work. I learnt to live with this but after last night and only having one fan speed. I needed the range of fan speeds to assist with the air conditioner especially today it's a scorcher.
Anyway thanks to this great and helpful sight I found the answer.
I need a new heater blower motor resistor. I took out the old one and found the old circuits on the resistor were badly worn away and there was a touch of corrosion on the rear of the resistor. Whilst in there I took out the fan motor and how dirty does it get in there.
Any how the part is on order and I need it as fast as there doesn't seem to be any relief in sight from this heat.
Thanks micra files.
Paul
Thanks micra files.
Paul
