Reinstall it, find out what the registry files are called from the installed folder, then uninstall and then check your registry’s with regedit and if the registry is still there delete it. Then close you internet connection all together, as it could be in use through internet explorer, then open task manager, look in processes and find the process that relates to the program and end it. Then you should be able to delete it. Also locate the folder it created on install and delete that, as I think it will still be there after you uninstall it. If that doesn’t work, get someone you hate and a good friend who drives, drive at about 60, and launch the computer out the window at the person you hates face... It won’t solve you problem...well it will... but it will also solve other problems in your life.
