CMF_Turbowheeler
» CMF Memberhi guys n girls(if there is any) i have a 998cc micra and i was looking at the diffrences between the 1L and the 1.3L all i can see is the size of the rods so could i just put the 1.3 con rods in 1.0 L (998 cc) bore>71.0mm stroke>63.0mm compression>9.5:1 power>58 PS (43 kW) @6000rpm 8.1 kg·m (79 N·m; 59 ft·lbf) @4000rpm DOHC, Multi Point Injection and then the 1.3 1992–present
1998–2000 1.3 L (1275 cc) bore>71.0mm stroke>80.5mm compression>9.5:1 power>79 PS (58 kW) @6000rpm 10.8 kg·m (106 N·m; 78 ft·lbf) @4000rpm DOHC, Multi Point Injection
so what do u guys think cos im stuck???
