First post so excuse me if ive put this in the wrong place.
Have just swapped cg10 with cg13 after head gasket started going on 1.0. Have fitted it to standard cg10 early gearbox. Firstly the clutch is barely biting and is at the end of the adjustment.
But the main problem is it's running really roughly. Seems to be way too rich stinks of petrol. Only seems to be a problem at low revs. Earlier the code readout was 21 I think. Which is ignition fault. But I think I've remedied that. Nowits reading 13 if I remember correctly.
If anyone's got any ideas they'd be welcomed
