B
Baker
I was jacking my car up & just before I was about to lower it the jack went through the sill & the car was being supported by the floor. the holes a bit bigger than the square on the jacks that are supplied with the car. The hole can only be seen if you look under the car. Ive been told that it can have a plate welded over it to sort it out, but will the car still be able to be jacked up safely (its the back passenger if that helps) & will it pass its next mot. Anybody had an identical problem? Whats the best way to repair it. (how do I put images onto my threads)
