B
beachbabe_6
Hi
I have an engine management light STILL on. I have an 01/Y reg Nissan Micra S.
The throttle body has been replaced.
The lambda sensor has been done.
The O2 sensor has been replaced (and again under warranty).
The garage now say that if the light comes on again (which it has!!) then I am stuffed as it is the ECU. What does this mean and is there anything I can do? Will the car break down? Will it pass an MOT with this fault apparent?
The best advice the garage could give was that they could take the bulb out behind the engine management light! Is this a good plan?
If there is no one here can advise can you suggest a technical helpline i can call for advice? Please.
I have spent too much on this getting it sorted to send it to the breakers but................
Regards
Sara
Oh just had full service done through independent so should be up to scratch.
Regards
Sara
