Help please ! My super s won't start :(
Hello people wonder if you can help. My super s is on 140k, been driving fine ... Went to leave work and she started up.... Ran lumpy for a second so I gave her a little Rev and on the drop of the revs she cut out and hasn't started since :( any ideas ? I've replaced the rotor arm and dizzy cap with no luck !
Any help experiences would be perfect
-------------also can you hear electric fuel pump on ignition up .has it ever been changed
ignition switch goes to
The engine / chains look and sound fine. I brought some easy start but still nothing. When turning her over she sounds like she's trying to start. Also has a spark.
Not sure if fuel pump has ever been changed... Didn't look like the dizzy cap had ever been changed either . If it was the fuel pump wouldn't easy start do the trick to test the pump ?
